Sheet Sets - Relative Path
I use Bricscad but all my clients use AutoCAD. I run all my work through sync (like dropbox) and rely heavily on relative pathing. I am finding that if I edit a sheet set in Bricscad the relative pathing is lost and all the links to the drawings are broken for my clients. They then need to go an repath all drawings in a set which as you can imagine is a frustrating time waster. I could not find in the settings anywhere in Bricscad where to change this, or anywhere in the user manual that mention it. Is it possible in Bricscad to have relative path to drawings in sheet sets? If not, this feature alone means I need to keep paying for AutoCAD.
