viewport overides
I am having an issue with Bricscad V18.
I have made up some layer states which I use to apply to different viewports in the sheet view. I also have colour overides in certain viewports. However, the colour overides are applying to every viewport that has a layer state assigned.
I even tried to have colour overides based on layer states but again, it was changing the layer colours in every view.
Is there something I am missing here?
  • There is a toggle in the _LayerState dialog: 'Apply properties as viewport overrides'. Make sure you have selected that option.
  • I have tried with both that setting set and not set. I am starting to think there is a bug in this file
  • Perhaps using _Audit can fix the problem. Or else send in a Support Request.
