general fix for many problems
I had made a few posts recently that did not receive any replies. I suppose it was because no one participating in this forum had had similar problems. This post is to give a solution to what I have found works for many problems. When I have had problems with the plotting in a drawing or, say, the inability to set points with my civil add-on, I have found that if I copy the contents of my problem drawing (making sure to keep the base for each as 0,0,0) to a new base drawing that has been proven to work in all aspects. So far, this has always worked to solve the particular problems being delt with. Of course it is essential that the new base drawing is a good one.
  • IS THAT THE SAME AS WBLOCKING THE PROBLEM???WBLOCK STRIPS A LOT OF STUFF OUT OF A DRAWING.SO DOES SAVE.TRY PURGE ALL?CLEAN??
