BLADE in German Bricscad: mixed English and German menus
Is the mixture of the languages
- indented or
- a bug or
- under development (until ...)
Suggest you file a support request - https://www.bricsys.com/en-intl/support/#63
@Per Gogstad said:
Suggest you file a support request - https://www.bricsys.com/en-intl/support/#63Done.
Thanks0 -
Yes, likely caused by incomplete translation :-(
(and there is lot to translate) ...
some defects with translatable strings are already fixed internally ... so next German version should be better then :-)
many greetings !0 -
Thanks Torsten
