Endpoint of a line coincident to another line
I cannot figure out how to add a coincident constraint of an endpoint of a line to another line. For instance, to make the right line bottom endpoint to coincident to the horizontal line, how to do that? It is very easy in F360.
  • Get rid of the (impossible) collinear constraint between the left and right line and things should work just fine.
    Ah yes, the collinear constraints should not be there. But how to make the two lines end points coincident the the lower horizontal line? Like the picture in F360?
  • I think I found it, select the second as entity, not point.
