Textures Bim compositons
Hey,
How do i get texture to bim wall compositions.
Can! Ad textures.
When you have a Composition added and double click on its Symbol,
you will get the Composition Editor. When you double click on one of
your Ply's Pattern it will open the Physical Material Editor.
In second Tab "Appearance" > 3D, you can double click on the
Material Preview to choose a Render Material with Textures.You can also find your Render Materials in Drawing Explorer where you
can manipulate your own Materials.
(You can't edit the Red Materials unfortunately)0 -
Re Installed bricscad on other computer here i see it and works. Thanks MM.
How can i update my wall with new materials,its not automatic updated in realistic mode? (only when i close and reopen the file its updayed)
How can i ad new textures to the library - with's i can use in compositions?
round walls still not have Ply compositions ?0 -
I think sometimes it needs an extra "Show Compositions" OFF/ON
to update Materials.You can create new Materials in Drawing Explorer and assign Image
Textures to various channels, to assign to physical Materials,
which you can add to your Compositions.Round Walls - not so far.
"Show Compositions" OFF/ON to update Materials
doesn't work for me - makes no difference. - still have to close and reopencreate new Materials in Drawing Explorer - Yes i now that
but how do i get my "own made" drawing materials - into the library materials.
i only see the library materials (comes with bricscad) wen i want to pick a material in compotision - physical Materials - apperance - 3D.
not the drawing materials0 -
'MATB' to open the Material Browser
The upper list shows the Drawing Materials, the lower list shows the Library Materials.
Select the desired material(s) in the Drawing Materials list and from the right-click menu, choose the 'Add material(s) to library' option.0 -
Thanks Hans0
