Drawing default Units
Hi everyone,
I have some issues regarding the drawing defatult units in v.16.
Everytime when I open a drawing the units are set to: Insches/ Imperial (Insertion Units: [1] inches/ measurement: [0] Imperial)
At this moment, I found a way using a default template: ''Default-m.dwt'' to set my units to [6] meters/ [1] metric everytime I create a new drawing, but, when i Open a drawing which previously was not saved by me it will opened with [1] Inches/ [0] Imperial units :((
For me, this is very frustating because I always use copy and paste to original coordinates and everytime i need to reset them by: UN command.
My question: Is there a way to set the units to Default as [6] metric/ [1] metric everytime I am using Bricscad?
thx all,
  • There is a command Basefile - if you create a file with your settings, or use an existing dwg and give basefile that dwg's name, it will open each new file as if it was that saved file.
  • You should be able to set the default drawing units to metric in settings.
  • Open the template drawing and make all the corrections then save it as a .dwt file this way it opens as a copy with all your settings inside.
    This is also needed for dimension settings etc..
    Depending of how you work you may need a few different templates. NEVER start from scratch .
    Correct, this is what I am doing now! All new .dwg or other .dwg processed by me will work. But if there is a new .dwg by a different name which came from an architect as example , it will still open in inch / feet :(.
    This was the first try, settings are not remaining as default.
    The start is not the problem, opeing a new different .dwg made by others is the issue.
  • Ahh then the problem is that some of the settings are stored in the drawing and you need to reset them in the on_doc_load.,lsp and make sure its loaded when opening a drawiing.
  • Sorry I didn't read the question properly.
    Patrick is right, you probably need to add (setvar "lunits" 2) in on_doc_load.lsp
