.Net GenerateSectionGeometry method does not work
The Section.GenerateSectionGeometry method does not work in the BricsCAD 17 and 18. The method produces the original solid at the output. It looks like the method ignores all the settings and always works in the SectionType.Section3d mode. You can check it out on the classic example.
The question is how to get a flatshot from a solid? If the problem is known, are there any workarounds? I can explode the solid and project all the curves to a plane, but how to separate invisible lines?
Dear Avc,
we recently fixed the Lisp/BRX/COM interface for GenerateSectionGeometry (not yet published) - so good chances that it will work in an upcoming update.
You might send us a SupportRequest (to keep track in our database), so we can verify wehter it actually works correctly, in our internal build
(the samples we have actually work correctly).many greetings !
Thank you. I will wait.
