show polygon area while drafting it
Hi all
I am starting a land subdivision and, being new to Bricscad, wondered if it's possible to dynamically show the area of a closed polyline as I move one side of it? Is there a setting in Bricscad or a LISP routine available to show this? Similar to how the line tool shows the length and angle while it's being drawn.
thanks in advance
Mike
I don't think this is possible without customization.
Workaround: You could create a field that refers to the area of an existing polyline, and then as you make edits to the polyline, the field will update (after a regen).
Looks like you are the same person that asked in this thread:
www.theswamp.org/index.php?topic=54155
I confirmed it works in BricsCAD if anyone else needs this.
Here is an short recording of it.
Fabulous
cheers
Mike0
