Recommendations for PDF-Import?
From AutoCAD I made from a drawing two different PDF - one with internal DWG2PDF, one Foxit-PDF, but same settings and same content. Then I imported these 2 PDFs to Bricscad V18.2 - and see a very different behaviour of OSNAP to the end of PDF-lines.
Are there some recommendations / experiences / best practice with "OSNAP and PDF"? Is the pdf-driver important? The scaling of the imported PDF (0.001 / 1 / 2000)? Something else?
Thanks
Peter
What about the snap performance if you load each of these in AutoCAD?
In other words, does AutoCAD and BricsCAD differ? Or is the difference in the PDF files?0 -
After quick test it seem to work fine in AutoCAD ..
