In IFC my window frame is transparent
When I export my model to IFC and open it in Solibri, my window frames are transparent.
When I classify my window as a Building Element, the glass and frame of the window are both NOT transparent in the IFC export.
Do the drawing materials that I use in BricsCAD not go into the IFC model ?
Dear Katrein
Can you please send in a support request and add both your DWG model and the IFC export? Our analysts will be glad to look into this matter.
Kind regards
Louis0 -
Recently I met your colleague Tiemen Strobbe. My 3DSolids had the color ByLayer. IFC does not handle that. We made the colors explicit and changed in Solobri the color palette. Its solved the problem.
