Command Prompt: No window pop-up after command, just additional questions
See attached.
When I type in a command, I get a bunch of other questions and not a pop-up window. What commands can control this? ATTDEF? FILEDIA?
Try PRINT command (vs PLOT command).
PLOT: "Plots drawings to printers and to files, through prompts at the command bar; this command is meant for scripts and routines."
PRINT: "Prints drawings to plotters and files through a dialog box."0 -
If this applies to other commands as well: check your CMDDIA setting.
Does CMDDIA actually control anything in BCAD? It doesn't that I know of anymore in ACAD (but it does in ACAD MAP).
@rkmcswain:
You are right CMDDIA is obsolete in BricsCAD as well.0
