TCASE: Changes the case of selected text or mtext (upper case to lower case or vice versa)
Fellow Lisp Geeks,
Currently testing BricsCAD to see if it will do the job of replacing Acad.
Problem #2:
Anyone have a lisp routine that will change text case from upper or lower to the opposite?
In Acad, TCase.lsp, TCase.dcl, & TCaseSup.lsp files were used; in BricsCAD selected text, but was "Unable to load dialog box".
Anyone know how to solve this issue or have a lisp routine that will change text case from upper or lower to the opposite.
Thanks, Mike
Hi Mike,
most likely you're missing the related DCL file.
TCASE is available in Express Tools for BricsCAD.
CAD Concepts0 -
Jason,
Again, thanks for the info on Express Tools for BricsCAD.
Mike0 -
Jason,
Thanks, that works just like I am used to using it.
Mike0
