Japanese Network Licence to english user intervace
Dear All,
I want to install Briscad to my PC,
Is that posibble if i download trial program from briscad web in english User interface and take activate japanese license after it?
or in instalation there are option for instalation in any language.
Yudika
Dear Yudika,
As you can see from the download page, every language has it separate installer. You dont have multiple languages in the same installer file. If you buy the Japanese license, you can use it both for the Japanese and English versions of BricsCAD. Those who buy the English license can only use it for the English version and no other languages.
Dear Per Gogstad,
thanks for you reply,
so when i install using japanese installed Disk ,there are menu change installation languange . aren't there!
Thanks
@Per Gogstad said:
Dear Yudika,As you can see from the download page, every language has it separate installer. You dont have multiple languages in the same installer file. If you buy the Japanese license, you can use it both for the Japanese and English versions of BricsCAD. Those who buy the English license can only use it for the English version and no other languages.
Dear Yudika
It can maybe help if you contact our partner in Japan, Alfatech, directly.
You can find their contact details on our contact page: https://www.bricsys.com/en-eu/contact/Best regards
Mathieu
Are you on Mac ?
Sounds similar to my problem when I bought Bricscad.
I had a several trial versions in english in the past and a few german trials
before I wanted to switch back to english.Although I used the english (only) installer I was not able to get rid of
german language rests and german settings.Support helped by advising to some deeper forced deleting of hidden
settings and files.0 -
Yudika,
You will have to download and install separate installation files for each language, but get in touch with Alfatech if you need more details.
Oh, meanwhile even I realized that Yudika is on Windows
As far as I remember it was at least not enough to just delete
the "config" file from library folder nor the whole user/library
Bricscad folders, maybe even not just standard deleting the
whole config folder (?)
Support gave me a Unix Terminal command with some delete
really anything and don't ask parameters, which finally let me
install the en_US Version.EDIT
Oooh, sorry I traped again in some Link Spamming Post,
hiding Links in my original Quotes ...0
