BeginDocumentClose Event in Document Class .NET API Help
I am use the follow code for send the user a custom message when the drawing be for close. But the drawing closes, and the example describes when you excute the method Veto(), you prevent or anulate the close for the drawing.
I take this code the an example from AUTOCAD .NET API, the example is the next:
_AcAp.Document doc = _AcAp.Application.DocumentManager.MdiActiveDocument;
doc.BeginDocumentClose += new _AcAp.DocumentBeginCloseEventHandler(docBeginDocClose);
public void docBeginDocClose(object senderObj, _AcAp.DocumentBeginCloseEventArgs e)
_AcAp.Document Doc = (_AcAp.Document)senderObj;
// Display a message box prompting to continue closing the document
System.Windows.Forms.DialogResult result = System.Windows.Forms.MessageBox.Show(
"El documento "+ Doc.Window.Text+" se esta cerrando" +
"\n Tenga en cuenta que esto pausara su actividad \n¿Desea continuar?",
"Información",
System.Windows.Forms.MessageBoxButtons.YesNo);
if (result == System.Windows.Forms.DialogResult.No)
e.Veto();
I hope someone can help me.
