Dragging *.dwg (wblock) file into ex't *.dwg
In Acad dragging blocks from a folder was simple.
Click on block in folder, drag into opened BricsCAD *.dwg.
Results in the *.dwg (block) opening as a new BricsCAD dwg.
What am I missing?
Change your DRAGOPEN setting.
You can also drag with right mouse button - then a context menu opens, with many more options (depending on dragged file type).
Roy,
Thanks, changing from On to Off worked. I knew it had to be a simple setting, just did not know what it was.
Perhaps reading through the list of sysvars in BricsCAD might be beneficial, just like I did in Acad 20+ yrs ago, my bad.Torsten,
Cool, even works w/ DragOpen 1, very nice option.
The more I get into BricsCAD the more impressed I am.Mike
