Problem with TEXT command
Hello,
I posted a support request on May 23rd regarding a problem I encountered with the TEXT command. I have yet to receive a response from tech support. Could anyone confirm what I'm seeing?
This is from my post to support:
**This problem occurs if you use any justification except the default (LEFT). Here is the sequence to produce the problem:
- Start the TEXT command.
- Choose any other justification option, for example MIDDLE.
- Pick the start point.
- Start typing. The text preview does not appear at the point chosen. It appears at the origin (0,0).
- Press ENTER to complete the line.
- The text now appears at the point chosen.
- This repeats until the command is ended.
If the default LEFT justification is accepted, the command behaves normally; the text appears at the point selected.
This didn't occur in the V18.1 release. This problem occurs on both my home and work computers. Both computers are running Windows 7 SP1, 64 bit, and are current with Windows updates.
I am running the latest version of BricsCAD CLASSIC, 64 bit.
Confirmed! Strange behavior indeed
I have some issues with DTEXT. Maybe related?
v18.2.14 on Win7 Pro.DTEXT [Enter]
Command Line prompt: “Text: Style/Align/Fit/Center/Middle/Right/Justify/:”
SELECT (point of text)
Command Line prompt: “Height of text <4">:” 6 [Enter]
Command Line prompt: “A positive value is needed. Please try again.” 6 [Enter]
Command Line prompt: “Rotation angle of text <0.0000>:” [Enter]
Command Line prompt: “Error occurred in mtext editor: Invalid input”- Prompt History:
- DTEXT
Height of text <4">: 6
Filed a Support Request re: above. 24 hr.s later, response:
Thank you for your report. We are aware of this issue, an internal task is already created and our development team is working on it depending of priorities.
Howdy, Stranger!
