image attach
I must have turned off a setting, because now I can't attach a raster image. when I select insert , it doesn't open my files. Help! what did turn off?
Going to need a bit more detail...how are you starting the command? Are you getting as far as selecting a file to insert?
FILEDIA setting ?
No. cannot select a file. I think I turned off a setting, don't know what I did.
Thank you! -
Are you using the IMAGEATTACH command? In your first post you said "when I select insert." But the INSERT command is for inserting a block.
Howdy, Stranger!
