Opening and linking to cloud 24/7
Great stuff I can read and maintain DWG files from the cloud! Even in trail mode for testing
Uploading #IFC and #DWG with the transfer tool works fine
Now some thing come in mind when using the 24/7 in BricsCAD BIM
- i would like to have the ability to 'cloudlink', both DWG and IFC.
- i would like to see an option to 'convert/ import IFC'
Just my thoughts about it.
As an example i post a screenshot from BIMplus environment using IFC files to build a model.
Hi Hans
I would like to have the ability to 'cloudlink', both DWG and IFC.
We don't really understand what you mean with "cloudlink", can you explain with an example?i would like to see an option to 'convert/ import IFC'
I guess you want to import IFC models in 24/7? If that's the case, we are working on that and it should be available by the end of the sumer.
'Cloudlink' i mean the ability to use xref directly to the stored cloud: dwg files.
Great to hear IFC can be stored and used onto 24/7 shortly. Maybe with the upload of a ifc file a converion on the background is started with some checkbox option? On servers, without user computer..0
