vla-setblocktablerecordid
I'm looking for 'vla-setblocktablerecordid' lisp function.
I'd like to insert a block into table with lisp program but I can't find the appropriate list function.
Is there any other way to get this result?
  • Dear Giuseppe,
    (vla-setblocktablerecordid) is present ... also all the others, with the "2" and "32" and "232" postfix;
    did you encounter any error message ? Which BricsCAD version do you use ?
    many greetings !
  • Hi I'm using Bricscad v18.1.17 and I get this error messge:
    ; ----- Error around expression -----
    (VLA-SETBLOCKTABLERECORDID BLK-TABLE ROW 0 (VLA-GET-OBJECTID (VLA-ITEM BLK-NAME)) :VLAX-TRUE)
    ; error : no function definition <VLA-SETBLOCKTABLERECORDID> ; expected FUNCTION at [eval]
  • Dear Giuseppe,
    that is strange - vla-setblocktablerecordid is present since a long time ...
    can you try
    (print vla-setblocktablerecordid)
    after BricsCAD startup ? It should be non-NIL ...
    You might also update to latest V18.2. version (its free).
    If the error still appears, you can try to re-register the BricsCAD COM interface :
    a) run BricsCAD once with "run as admin"
    b) and/or
    • open a DOSbox (cmd.exe) with admin rights, in BricsCAD's install folder
    • run "regsvr32 axbricscadapp1.dll" and "regsvr32 axbricscaddb1.dll"
    many greetings !
  • @Torsten Moses:
    This is the Linux forum. So the question is: Has this function already been added to the 'Fast-Com' set?
  • Torsten Moses
    edited June 2018
    Dear Roy, Dear Giuseppe,
    arrrgs - my fault :-(
    Our Tijs also notified me about ...
    indeed, vla-setblocktablerecordid is not yet available for Linux/Mac ... so I have to promise to make it available for V19.
    If you need more VLA stuff available, please send us a support request with the missing function,.
    Another hint : the "Lisp Developer Support Package" (free download from our AppCatalog) also documents all COM properties + methods, which are already availabel for Linux/Mac.
    many greetings !
