Export data points via DDE
I have previously exported block attribute data to Excel from AutoCAD using DDE,
In this new project I want to export map coordinate positions from BricsCAD to another program (Not Excel) and can only think of doing it via DDE
Do you have an example of how to set up the link, as I do not have access to my original code.
Thanks
BricsCAD does not have DDE (Dynamic Data Exchange). Try using the _DataExtraction command.
