Layer Mapper/Translator
Hi there,
We have the need to be able to translate our layer/blocks/colors/etc from our system to that of a client. Does anyone have any solutions?
I found the Sofoco Tools application in the Bricsys App Catalog but it doesn't appear to work in V18 of BricsCAD.
Thanks in advance for your reply.
Phillip
Here are a few options:
https://goo.gl/8EXgxz------------- Layer Translate -------------------
http://www.theswamp.org/index.php?topic=36566.0
http://www.theswamp.org/index.php?topic=30327.msg359285#msg359285
http://www.theswamp.org/index.php?topic=5835.msg71232#msg71232 Rename
http://www.theswamp.org/index.php?topic=54161.50 -
Thank you Charles. I will check out those links.
Phillip0
