Opening new file in the same window.
Set SINGLETON = "yes" and then close and restart Bricscad.
On my system, after closing Bricscad I sometimes have to open the Windows "Task Manager" (by right-clicking on the Taskbar), and select "bricscad.exe" in the "Processes" tab and click on "End Process" and then restart Bricscad.
Thanks a lot. It is working now.
In Bricsacd V14 i cannot make document tabs visible. I can change drawings by clicking ctrl + tab. In newest version command SHOWDOCTABS is working. How can i change in older version ?0 -
Document tabs weren't included in Bricscad until recently, but before that there was a very good add-on, DocTabs by Daniel Marcotte. I can't find it in the app store now, but perhaps you can get it via a private message to Daniel.
