Entmake in Lisp
I am trying to place some ATTDEFs from a point in my drawing, but it puts them on (0,0) every time. What is wrong with this code ? Do I miss something or is the order wrong?
(entmake
(list
(cons 0 "ATTDEF")
(cons 1 "S3BA-100100BV")
(cons 2 "CODERING")
(cons 3 "Onderdeelcode")
(cons 7 "ISO")
(cons 8 "$attribs")
(cons 10 att_insp)
(cons 40 1.0)
(cons 50 0.0)
(cons 70 0)
(cons 72 1)
(cons 74 2)
(entmake '((0 . "ENDBLK")))
point att_insp is (2000.0 1250.0)
Jeroen
  • Since the justification is MC you have to supply the alignment point (gc 11). Note: gc 10 is also required but any point will do.
  • Even when I use the next code AND set OSMODE to 0 it puts the ATTDEF @ (0,0)
    (setq entlist
    (list
    (cons 0 "ATTDEF")
    (cons 100 "AcDbEntity")
    (cons 8 "$attribs")
    (cons 100 "AcDbText")
    (cons 10 att_insp)
    (cons 40 1.0)
    (cons 71 0)
    (cons 72 1)
    (cons 1 "ca-bltext")
    (cons 7 "ISO")
    (cons 100 "AcDbAttributeDefinition")
    (cons 2 "CODERING")
    (cons 70 0)
    (cons 73 0)
    (cons 74 2)
    (entmake entlist)
  • I tried to use the same order as in one of my other lisp-files. but still point (0.0 0.0 0.0) is used for the placement.
    (setq entlist
    (list
    (cons 0 "ATTDEF")
    (cons 8 "$attribs")
    (cons 10 att_insp)
    (cons 11 '(0.0 0.0 0.0))
    (cons 40 1.0)
    (cons 71 0)
    (cons 72 1)
    (cons 7 "ISO")
    (cons 2 "CODERING")
    (cons 70 0)
    (cons 73 0)
    (cons 74 2)
    (entmake entlist)
  • SOLVED IT:
    (setq entlist
    (list
    (cons 0 "ATTDEF")
    (cons 8 "$attribs")
    (cons 10 att_insp)
    (cons 40 1.0)
    (cons 41 1.0)
    (cons 71 0)
    (cons 72 1)
    (cons 7 "ISO")
    (cons 2 "CODERING")
    (cons 11 att_insp)
    (cons 70 0)
    (cons 73 0)
    (cons 74 2)
    (entmake entlist)
    Thanks for pointing me to the right direction...
  • More information if you are interested:
    https://goo.gl/nrkJmC
