Problem with opening 3D models
I have a model from the manufacturer in the STEP format. When I want to open it, BricsCad will stop working. I have converted the model to IPT format in Autodesk Invertor. This format has the same problem, though it should be supported. That's why I converted the model to DWG (again in Invertor). BricsCad opens it, but if I want to have multiple models in one set, it takes a long time (copy, bindings).
When I open this model in Autodesk Invertor and it converts it into an IPT format, it all works super. Is there a way to set up BricsCad to make it work? Best without turning everything into DWG, because larger STEP models (35MB or more) do not open BricsCad.
Thank you in advance for the answers.
I forgot attacht model. There are:
Hi Slavin
I suggest you create a support request (and attach your file) for the Communicator: https://www.bricsys.com/en-eu/support/#13
Mathieu
