Communicator installation check failed: MSVC runtime check: FAILED
Caught the following error whenever importing files (tested on STP and IGES format)
: _import
Cannot import file: [...].stp (Communicator installation check failed: MSVC runtime check: FAILED.)
So the import process does even not start.
Communicator
  • BricsCAD-Communicator-V18.2.01-1(x64)
has been (successfully) installed on bricscad
  • BricsCAD-V18.2.14-1-en_US(x64)
MSVC runtime are installed, as shown herebelow
Which is the exact MSVC runtime dependency?
Thank you
Tyia
  • Suggest you file a support request - https://www.bricsys.com/en-intl/support/#13
  • If anyone else runs across this issue, the fix is to install the "Visual C++ Redistributable for Visual Studio 2012 Update 4" package which contains the necessary msvcr110.dll file.
    This hit me this afternoon, running BC 18 + Communicator on a fresh re-installation of Win7 (the original Win7 had developed a bad case of BSOD). All good now.
