Set by layer
Hello
Can somebody look where is the mistake in code below to
automatically run command: "setbylayer" ( set by layer is another lisp program that can be download from here http://www.b-k-g.nl/bkg_setbylayer.html).
This is my try but it doesn't work
. There is message " There need to be point. Try again"
(defun c:QQ ()
(command "_selgrips" "_all" "BKG_SETBYLAYER" "OK" )
(princ))
@Brian12345:
BKG_SetByLayer is dialog driven. It cannot be used in this manner.
This does work:(command "bkg_setbylayer" "_all" "")
But you will still have to manually click the OK button.Maybe I'll one day create a command line version.
Thank you it is work as you say by manually clicking "ok" it's not perfect but it's ok to me
