Dmpushpull command
Hello ,
I can not use the dmpuspull command. There is an allow / disallow setting in AutoCAD for this, Do you have Bricscad?
Best Regards.
What is your license level? DmPushPull is available in Pro and Platinum, not in Classic.
license level : Bricscad Platinum
If this about the Quad: start with a different profile.
@simsekfatih said:
Hello ,I can not use the dmpuspull command. There is an allow / disallow setting in AutoCAD for this, Do you have Bricscad?
Best Regards.
I just noticed you put "dmpuspull" in your question. Is it just a typo?
@DFLY said:
Best Regards.
I'm sorry. İt just misspelling
