fly-out
Hello,
I have re-installed Bricscad, but do not know anymore to remove the fly-out by touching an object.
See the attached file.
Regards, Peter
In your status bar at the bottom on the right side there is the "Quad" button.
you can deactivate the Quad Menu from there.
You already did that for the Rollover Tips that would show object properties
otherwise, when hovering over an object.0 -
Thanks Michael, that solved the problem.
