Circle by means of tan-tan-tan
Am I overlooking something of does Bricscad not have the possibility of drawing a circle by means of 3 tangents ?
  • Ai_CircTan
    Draws a circle tangent to three entities.
    command bar: ai_circtan
    ai_circtan
    Enter Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
    Enter second Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
    Enter third Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
  • @fs_at12
    Thank you kindly. Much appreciated.
  • Isn't that an entry for the prompt menu when you enable
    "show hidden options" ?
    (PromptMenuFlags)
    Edit :
    No, it was just TanTanRad
