Modifying setvar CmdLineListBGColor
Hi there,
Is it possible to modify these setvars through lisp??
- CmdLineListBgColor
- CmdLineListFgColor
- CmdLineEditBgColor
- CmdLineEditFgColor
Thank you advance for your reply.
Phillip
You should be able to use the setcfg function.
(getcfg "Name") (setcfg "Name" "Value")
Using Getvar / Setvar also works
(getvar "Name") (setvar "Name" "Value")
Getcfg + Setcfg gives access to all values defined within SETTINGS. You do need to be aware that values are given and set as strings.
CAD Concepts0 -
Thank you gentlemen... duhhh... not sure what I did earlier today but for some reason I didn't seem to be able to retrieve the value with getvar.
I feel silly but I'll get over it. Thanks again.Phil
