Define Attribute Panel Freezing
I'm using Version 18.1.09(x64) and every time I open the Define Attribute Panel (attdef) it freezes if I try to change the text style or justification. The lists drop down and freeze. If I switch to another application the list box persists in the foreground which may be a video card issue but am open to suggestions.
Any ideas anyone?
Thanks,
Phill
Hi
Did you already test with the latest v18 release?
If it still is an issue, you should a ticket in the support portal. https://www.bricsys.com/en-eu/support/Regards
Mathieu
Update to 18.2.20 worked. Thanks.
