Exporting / Importing Tool Palettes
I exported my tool palettes group (under the group there are several palettes). However, when I import the palette group on a different computer I get only the group...
How to export the group, including, all palettes?
As far as I'm aware BricsCAD doesn't provide a tool for exporting Tool palettes. You could raise a support request to ask for this feature to be added.
To copy tool palettes to another computer you would need to open the folder specified by TOOLPALETTEPATH and in the palettes folder copy the the .btc files along with the images folder. There will be a .btc file for each tool palette that you've created. On your target machine you would then use the import option to import the tool palettes that you want.
If you want both machines to have identical Tool palettes setups, then you can copy the entire folder structure across to your target machine, replacing the existing files.
It is best to do these changes with BricsCAD closed down.
CAD Concepts0
