Invalid group code
Hi all,
When trying to load a saved DWG that I have been working on only a few hours ago, I get An error occurred while loading the drawing? so a few times now gone back to an earlier DWG version and redo all I have done so so well I hope you can help me on this one, also it says try recovery but no clue on how to do that tried loading back up file but no good.
Many thanks all.
To recover a drawing run BricsCAD and then:
- Do one of the following:
- Choose Recover in the File | Drawing Utilities menu.
- Type recover in the command bar, then press Enter.
The Open Drawing dialog window displays.
2. Select the drawing, then press the Open button on the Open Drawing dialog window.
The drawing is repaired and - if the repair succeeded - opened.
3. (option) Press F2 to open the Prompt History window in order to read the recover report.You should in general try to run an Audit on all drawings once in a while and then fix errors. Se this link for more details:
thank you Per Gogstad for the prompt reply, unfortunately none of the above has worked
Then you should file a support request and include one of the files you have problems with.
thank you, I have now put the question to support.
Cheers Per Gogstad.
Cheeco,
did you ever get a fix for this?
