Select by properties: what is meant by 'Value'?
I was only very recently made aware of the 'Select by properties' selection option (see this topic). Most of the property options are clear, but I do not understand the 'Value' option. I have testes with attribute values and radius values, but both did not work. What is meant by 'Value'?
