No file name entered
Hmmh,
all my Files are on an external SSD and I have no problems.
I'm on Mac.If you would have your file on a Server, I would assume that
the error message is not showing exactly what the problem
is and that it has something to do with access or write rights.Maybe it is worth to check file rights although it is a local disk.
Another idea is that the File Name uses special characters
which Bricscad does not like in that case ?0
