Bricscad.exe: Command-line option "/ld" used also for every new file
The command line options are described to run when starting Bricscad.exe; "/ld" loads an additional application while starting.
But I see that the app which is defined under "ld" does not run only when starting, but it is loaded during an existing session every time when I start a new drawing or open an existing one.
Bug?
Feature? (Then please describe it also in help-file.)
  • I've noticed this behaviour too. I believe its useful, as you say just needs to be documented better.
    If you only want the application to run during start-up try "/B" instead. Help infers that this option is limited to script files, but it also works for LISP. Again useful, but not documented.
    CAD Concepts
  • Thanks Jason
    let's wait a little bit - I hope that Bricsys read this topic too (and promises an extended documentation)
