Text Mask not hiding geometry
This just started having an issue with BC Pro 18.2.20 64 bit
I apply text mask to the Mtext, do a draw order front. And tried selecting geometry & Draw Order Back but still in model space the mask is not covering the objects.
Anyone else having this issue?
Forgot to say that the masked text prints to PDF with the mask correctly but will not display on the monitor correctly.
Do I never know if the mask was applied or not.0 -
I'd like to test this, but how can I go from v18.2.04 to v18.2.20 ?
The current version on the download page at https://www.bricsys.com/protected/download.do is 18.2.20-2.
Thanks for checking.
I found the issue, in Model space with nothing selected the Visual Style was set to Gourdaud.
When I changed it to 2Dwireframe the problem stopped.
I could not find Gourdaud in the pick list after that.Must have set that 3 months ago when I was last in the drawing.
BTW, that setting if used through a viewport causes my setup to print in color for that viewport.
All other viewports print in Black & White, all set to "Print To PDF.pc3"0
