Annotative mleaders and annotative text in general
Hi there,
We have been encouraged to add the issues we are having to this forum to ensure you understand the bugs we have found.
We are still having serious issues with annotative multi-leaders when editing them and changing scales.
When we setup the text at 1:250 and 1:500 and then edit the text or switch between scales the leaser will blow out to be extended or the annotation text height will be removed, and text will remain at one scale. This happens irrespective of the annotative setting being on or off.
Are you aware of this bug and do you have any ideas on a timeframe for a fix ?
Running 18.2.20
Howdy, Stranger!
