Fatal Error at file char 31
Hi All,
Please can someone help me. I have just has a Xerces error come up saying - Fatel Error at file C:\User\Ashley\AppData\R...\default.cui, line 23844, char 31
This is happening on every saved file that i have, that leads to about 1000. Also any new file! This message will pop up and the only thing i can click on is the menu button within Bricscad.
Thank you
Ashley Trice
Please copy the default.cui from BricsCAD installation folder (under UserDataCache) to your user folder (that folder as shown in the message);
seemingly, the default.cui file became corrupted :-(hope this help ?
Thank you for getting back to me so fast. Sorry could you step this out a bit as do not understand and spent the past hour looking.
Thank you0 -
Hi, just spent another hour trying to locate and understand this with no luck. Sorry if I am acting dumb but even the folders won't come up.0
Dear Ashley,
please look into your BricsCAD installation folder - there you will see the "UserDataCache" and its sub-folders, usually like that :
/BricsCAD V18 x64/UserDataCache/Support/en_US/there you should find the "default.cui" - this file can be copied to your user-folder
C:/User/Ashley/AppData/Roaming/Bricsys/Bricscad/V18x64/en_US/Support
(the folder as shown in the messagebox, "en_US" might be a different locale identifier, depending on your system + installation)Copy the "default.cui" into that folder, overwriting the existing, potentially corrupted default.cui ...
(re-installation or repair-installation might also help to replace the defect file ?)good luck, hope this helps ...
