Hi, I have a Problem regarding extrusion.
After I extrude a drawing I lose all track to the drawing itself (I cannot find any reference to it, in contrast to AutoCAD).
Is there a possibility to change the drawing after the extrusion to change the extruded part?
Hi Roy, I am very thankful for your answer.
Unfortunately that will be a limitation that will prevent me from switching to BricsCAD.
It would be quite interesting to learn what it is that becomes impossible to achieve without this associative link:
in many cases BricsCAD direct modeling can apply desired modifications directly, without the need to go back and modify the source entities the solid has been created from.
