Reinforcement
Hello! I work as a design engineer. Work with BIM began not so long ago. At the moment it is not clear how to set the reinforcement of columns, beams, foundations in Briksсad BIM. What functions can I use to set it? It is also interesting to look at the finished building developed in BIM.
I hope for your help.
Sincerely, Maxim Skoriantov.
for such specific requirements you need additional apps like
https://www.bricsys.com/applications/a/?artifex-reinforcement-a358-al879
https://www.bricsys.com/applications/a/?bbaucad-bauingenieur-a254-al408but you can also model the reinforcement and then classify it as a BIM object "other"
define them as Building Structure Elements
look "BimClassify" in the helpfile for more information.
