Activation error: No rehostable hostid top-level dir (error code -148)
Hello,
What is wrong when I get the following error code when trying to activate licence for BricsCAD Shape V18.2.06 (x64) in a Windows computer: "Activation error: No rehostable hostid top-level dir (error code -148)? How can I fix it? See the attached screenshot. I have reinstalled software, it did not fix the problem.
Thank you for the advice!
  • Hi
    I advice you to create a support ticket here: https://www.bricsys.com/en-eu/support/#86
    Regards
    Mathieu
  • HI
    I was the same problem on linux. Solution for my problem it was permission to file (LicenseManager.cfg) and directory.
    I added permission to write for user and group, before user (root) has read and access and group (root) only read permission.
  • My error was "rehostable host id exists (-153) Bricscad" In Fedora 30 I had to delete the /var/tmp/bricsys directory.
    rm -r /var/tmp/bricsys
