Sweep on path inverse the shape
I encounter strange issue, the result of the sweep is the invert of the sketch, which is not my expected.
What kind of help you need ? Could you please elaborate so that community can help.
If you look at the sketch, the sweep does not follow the shape of the sketch, but reversed.
@fredericklim:
Switch to the WCS first.0 -
edit POLY
and reverse the direction of your sweep railPEDIT R
@Roy Klein Gebbinck said:
@fredericklim:
Switch to the WCS first.Switched to WCS works. Thanks!
@fs_at12 said:
edit POLY
Could you show what command should I use?
type in PEDIT select the polyline and then type R (for Reverse direction)
thats it0
