Bimsection markers
The section callouts should be deleted along with the section. Can you send in a support request and add the model?
Seems they go away with close and reopen - they've gone from the attached.
In order to access the 2D line I wanted as base for the sectionplane, I had to open the 2D plan Block with Refedit, so the sectionplane was created as part of that Block, before I minus'd it out of the Block before closing Refedit.
Maybe that's the problem.
No section callouts found. So far so good?
It's tolerable, as they go away with reopen. Cd it be because they were created in the Block? Wd you like to open it with Refedit and try creating one?
Sections should not be created inside the block reference. Entities in blocks will be processed correctly by BIM Section entities.
Thanks Louis
