LISP compatibility - strcar, strlen
Hi, does the LISP environment in BricsCAD handle "strcat" and "strlen" functions? I have a lisp from AutoCAD and in BricsCad it stops working around that expression.
  • The strcat and strlen functions are available and compatible. Both functions require strings as input. I suspect the problem lies there.
