configuration files
configuration files
I installed BricsCAD on my computer
I now need a custom configuration file that I am using to copy to a handheld computer so that it works as on a desktop computer
  • you can :
    a) export the current profile (see ProfileManager application in BricsCAD), and import that on target machine
    b) if you are familiar with regedit.exe, you can also export HKCU/Software/Bricsys/BricsCAD, and import that created file on target machine
    But please be aware, that also all path + folder references are copied as they are ... so ideally, your handheld machine should have the same folder structure etc.
    many greetings !
