View detail and generate draw vievs.
Hello. It's my first post here so my name is Mario.
It's my first work on Bricscad so i have some question.
Please tell me how i can create View detail and generate draw vievs.
Thanks
  • The ViewBase command creates views of the 3D model. See the BricsCAD Help under Command Reference / V / ViewBase.
  • Is any way to create this element ?
  • Attach an example of your element created as a 3D parametric Model with 2D view generated from it using VIEWBASE. The holes have been created as a polar array on a separate model which is then inserted using BMINSERT to create.
    VIEWBASE requires BricsCAD Pro or greater. To apply constraints & parameters etc requires BricsCAD Platinum.
    CAD Concepts
