Replace _sectionsettings.dwg with my_own.dwg?
We know, the seetings for sections are defined like this:
When creating a new BIM section the settings of the newly created section are copied from the sections in _SectionSettings.dwg. You can find this drawing in the C:\Users\UserName\AppData\Roaming\Bricsys\BricsCAD\V18x64\en_US\Support\Bim\Sections folder
I know that I can modify this drawing.
But - can I replace the path and name with (for example) "d:\data\my_own_settings.dwg"?
The name of the file must be _SectionSettings.dwg. You can edit the existing file or save your own in the same name.
Thanks Louis
OK.0
