[19.1.06-2] : SELECT -> COPYCLIP -> QNEW -> PASTECLIP : Crashes
I used these commands in this order without any problems with version 18 but now it crashes on version 19.
The same appends with CTRL+A (selgrips), CTRL+C (copyclip), CTRL+N (new + default-mm.dwt) and CTRL+V (pasteclip).
Please file a support request an add the drawing you are having this issue with. I could not reproduce your scenario.
In fact, the copy/paste process is terribly slow (this is why I think that the application crashes).
For some of my files, it is 10 times slower than version 18.
I've also a big file with ~88000 "objects" and after 10 minutes, it ran "out of memory".
At this time, I remain in v18.
Kr,
Problem solved with version 19.1.07-3
